turbo for a s-type, 1999 (T) what to use and what other mods will be required
could anyone please help me, i have a s-type and i want to put a turbo (or two small ones) on and does it need a modified exhaust etc ? and please let me know what makes (or websites to buy) thank you so much for any constructive help, jordi
Received 2,263 Likes
As stated by other members, the cost of this would be massively prohibitive and the work involved would require so much specialist welding & machining that you'd be far better off buying an R.
A custom ECU would be needed, or at the least a piggy back ecu; and I don't know of any for Jaguar engines. For Japanese engines they are two a penny (Greddy etc) but for this marque you'd be on a first. Zytec would be a possibility as this was used on the XJ220 and Aston DB7..... Maybe even Megasquirt if you fancy the DIY route?
Looking at the costs involved you'd probably be paying:
£500 for 2 turbos (assuming one per bank)
£500+ for each manifold
£500 for Megasquirt
£1500 for low compression pistons
etc etc
I'd budget £4k+ in all. Thats in the bottom bracket of S-Type R money
£500 for Megasquirt
etc etc
Jumpin' Jag Flash (07-06-2013)
i was told by a quilified mechanic how to do it and what i would need, he said it'd be alot and i thought about having a look why is every body on here so criticizing on here, but thanks to the few
Hi Jordi, here's a question for you.
What is it that you are trying to achieve, by turbo-charging a 3ltr v6 engine, please?
I really would like to know.
Just looking at the numbers should tell you all you need to know, bare in mind all cars weigh roughly the same:
3.0 v6 - Power: 179 kW , 240 HP SAE @ 6,800 rpm; 221 ft lb , 300 Nm @ 4,500 rpm
4.0 v8 - Power: 209 kW , 281 HP SAE @ 6,100 rpm; 287 ft lb , 389 Nm @ 4,300 rpm
4.2 v8 - Power: 219 kW , 294 HP SAE @ 6,000 rpm; 303 ft lb , 411 Nm @ 4,100 rpm
4.2R v8 - Power: 291 kW , 390 HP SAE @ 6,100 rpm; 399 ft lb , 541 Nm @ 3,500 rpm
Here is my advice - forget the dream of turboing your S Type now and instead just buy an S Type R.
I have turbo charged a NA Mercedes in the past and it cost a fortune. In the end, it would have been cheaper for me to buy an AMG version of my old Mercedes and it would have come with more power, better resale, cooler interior, seats, bodykit, etc. and better brakes.
To turbo an NA car you can only run low boost (i.e., 5 PSI) which is nothing, def not worth the money, hardly any power gains. My old turbo'd Mercedes was still slow given the cost of the car and what I put into it compared to what I could have traded my car in and purchased.
To run proper boost you would need to lower compression, get forged pistons/rods, etc. and tune. Its not going to happen unless you dump many thousands into it. And then even if you build the motor to handle proper boost, your tranny likely won't be able to handle the power. And on top of that, you would probably need wider wheels to handle the power ($$$) and then a big brake kit to stop the thing (again $$$). Theres a lot that goes into making a normal sedan into a super sport sedan. Thats part of the reason (other than the hype to the name) that one is well into the six figure range for an otherwise normal Mercedes E Class once its been modified by the likes of RENNtech, Brabus, Etc.
If you just sell your car and buy an S Type R, you get the cool interior, the powerful engine, the big brakes, proper suspension, and an ECU mapped to bring it all together. Its like buying a mega dollar tuner car on the cheap.
Here is an example - the previous generation Nissan Xterra was offered as a supercharged version. All they did was slap a supercharger on, and it only made 3 PSI!!! Thats because they didnt want to spend the $$ coming up with a whole new engine. I think the MazdaSpeed Protege was the same story, that car only made like 5-6 PSI. Its not worth it. Surrender now to an S Type R and let this thread die.
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
But there are forum rules for a reason, and you should familiarize yourself with them before going any further. Your ignorance about forum etiquette, your lack of research before posting your questions, and your belief that you are busier than others on this forum is insulting.
Don't expect much in the way of hand-holding by forum members on your project as most of us are way too busy.
FS[SouthWest]: Parting out 1999 Vanden Plas
Brewmonkey
21
05-30-2016 12:50 AM
Brewmonkey
09-20-2015 01:43 AM
