Two shops refuse to install the 3lb pulley with the S/C on the car...
Anyone run into this? Can anyone offer some words of wisdom I can use to try to perused the mechanic? One shop said it was an 8 hour job but thinks he can do it in 7...With that much labor, new gaskets and the price I paid for the pulley we're talking $750-$1000 range...I just can't justify that much and would honestly rather sell the pulley and go a nitrous route...
The right way to remove the upper pulley on the car involves using a rather large puller. Some tell you to split the pulley, this is something I recomend against. There is no reason to remove the supercharger to take the pulley off. You need to find someone who actually has a supercharger pulley puller.Here is an example.
![](http://www.pulleyboys.com/images/store/pullerThumb.jpg)
I've done both pulleys. The stock pulley can be cut off to save time and money for a direct press on 1.5 pulley...need more? if you haven't a puller, cut off the 1.5. A decent shop can use the Phoenix Coach Works dummy pulley (Mafioso may let you borrow his, as I had) as a guide for grinding down the snout (a skilled machinist can do this in two hours). You'll be very satisfied with the low down torque and hp the 3 lb pulley affords. My STR can burn-em for nearly 75 yards before she'll hook-up. Prepare yourself to procure a "Killer Chiller, as this will be definitely necessary at this juncture. A pair of hi-flow cats and x-pipe will compliment the new found boost.
rachelstr
09-03-2015 12:59 PM
