Uh-oh, another STR on 20s
The following 2 users liked this post by Michael Star:
Bacardi 151 (04-28-2012),
Panthro (06-03-2012)
Mine
The issue is on the rears you have to run a spacer to clear the brake caliper. I'm not a fan of it but that is the only way. Speaking of which, does anyone know where I can get longer wheel studs?
https://www.jaguarforums.com/forum/s...spacers-71693/
Yes, these are 20x8.5 front and 20x10 in the back. I will have to get the dimensions of the spacers as I am unsure of the thickness, but they barely clear the brake caliper in the back (fronts are fine). I'm not a huge fan of this style of spacer, and I do want to get some longer bolts if I can find them.
I bought these wheels second hand, so I don't know the offset, but I bet they are made for the XKR. You are correct that you can run those wheels, but you need to push them out a bit.
I still need to roll my fenders and have a bit more negative camber added to the rear (to make the outside, top edge of the tire tuck in better.
Panthro (04-30-2012)
SoCalJagS
09-27-2015 09:20 AM
