Under-Cowl Foam Insulation Deterioration and Removal
If you've owned your S-Type long enough, you already know about the deteriorating grey foam insulation in the engine compartment underneath the cowl. After a few years it tends to sporadically flake off and float all around the engine compartment, making a general mess....
This past Saturday I was using my electric leaf blower to blow debris off the car (less debris means fewer chances to clog the moonroof drains). While blowing around the windshield and cowl area, I noticed some of the very small grey foam insulation flakes being whooshed up into the air. So I opened the hood, pointed my leaf blower underneath the cowl area, and gradually blew off all of the remaining deteriorated insulation. Took me two or three minutes until no more insulation flakes were floating out of the area....
I think that effort finally removed all of the remaining insulation that has continued to sporadically flake off during the past couple of years. We'll see....
One word of caution: A gas-powered leaf blower may be too powerful so if you opt to use one, keep the speed low. You don't want to be blowing off any trim pieces or brittle hose connections. My electric leaf blower was perfect for the job....
Jumpin' Jag Flash (06-19-2013)
Well your way is better than how it normally goes!!
I had that crap all over the engine compartment before I found where it was coming from. First mistake was trying to remove the foam while it was still in the car. What a mess! Finally took the panel out and cleaned it all off with my hands and followed that with some solvent to get all the crumbs.
