Underhood temps
Underhood temps
Hi guys. We got off topic and were talking about underhood temps in my thread about the intake elbow. I thought I'd do a little research into this topic and post what I found.
I have a cheapo indoor/outdoor thermometer with a wired probe. I put the probe behind the driver's side headlight where my car takes in air (stock airbox is removed; it's how the car came). I drove around town both in the morning (about 63*f) and during mid day (83*f).
What I found is that when stopped the underhood intake temps increase quickly. In the morning the temps would get to above 120 after a long stop light. During the mid day, temps would exceed 140 (max on the unit). Upon driving, temps would quickly drop to within 10* of ambient within 1/4 mile of driving.
I also was on the freeway today with temps about 70* and noticed that at about 25* temps would remain even and above that at 30mph, the underhood temps would start to drop. Anything above 35 and the temps would drop pretty quickly.
A few things to note, the thermometer didn't show real time temp changes, so it could have been slow going up and slow coming back down.
Basically beyond 30mph, even with my "hot air intake" setup, the engine is breathing near ambient air temps.
I will try to measure with a infared heat guy later and see what temps the various pieces of the intake tract are. I have one but need to find it. I'll update the thread once I find it.
So, to the people that say that an exposed cone filter is the end of the world... it obviously isn't. it's not ideal, but it's not going to kill your performance once you're moving.
The following 2 users liked this post by qwiketz:
Mikey (04-03-2012),
The Chris X (04-03-2012)
Received 2,263 Likes
Junk the hood blanket, its like a 20 Tog duvet for your engine!!! i'd also paint the underside of the hood matt black (absorbs heat)........also will be good for cooking eggs on the hood if you ever take the jag for a pic nic
Totally correct though the hood blanket in main will be to keep noise levels down in the cabin and to a certain extent stop the hood paint on the top surface getting scorched if/when the engine gets too toastie.
My race/track car has a similar set of issues only twice as much as there are dual air filter/intake tracts because it's twin turbo. Some people have gone to the cone style filter sitting behind the headlamps but I stayed with the stock box because it has a snorkel like intake that extends under the headlamps and directly into clean air. Once I'm out on the track it probably isn't much different because of the huge air flow track speeds. It's not a drag car.
dmatthewman
09-30-2015 10:10 AM
