Unexplained Beeping!!
Guest
Posts: n/a
My Jaguar S Type is beeping from under the bonnet every 30 minutes or so, for 20 - 60 seconds or so. I've checked the battery (fine) the doors are all closed properly, glove box is closed, No other warning lights/messages or anything and the car drives perfectly normally. What can it be? Its driving me insane!! Thanks!
Guest
Posts: n/a
Um.. its unlikely, the car is 2004, the previous owner didnt seem to use it at all and I had a total bargain! Nothing has ever been wrong apart from this anomaly *touch wood*
So I doubt there would be an aftermarket alarm on it, however its possible the siren itself is 'loose' or just broken!
Another thought however; when I tested that the alarm system responds (i.e. I left someone in the car to see if it went off, and , entered with just the key, and it went off ) the noise that was made was the horn intermittent hoot, along with the very same "beep beep beep" - however is there supposed to be a separate siren?
