Upper Front/Rear Control Arms
Hello All,
I know this may sound a bit crazy but I want to know what you guys think.
I recently replaced the front upper control arms and want to experiment with the old parts as opposed to throwing them out. The bushings were in pretty bad condition and the dust boot was totally gone on the upper ball joint. In addition, this BJ is loose and can be moved from side to side with little force. On the other hand, it does not have any "up and down" play.
I am in the process of having someone attempt to manufacture the bushings in a local shop. My issue is with the ball joint. I have seen indivuduals tap and install a grease zerk on sealed BJ's and inject grease. I would also try to find a suitable dust boot replacement.
Again, this is only an experiment, I am looking for alternate solutions for the rear upper control arms. What do you guys think, is this attempt a waste of time?
Received 2,263 Likes
Yes, unfortunately the front upper bushings were very bad. I was also a little concerned because the boot on the upper ball joint was non-existent. The lower ball joints were replaced at the same time. This was a real PITA as the whole lower arm had to be purchased. I made a thread about the lower ball joints about two weeks ago.
I will certainly post pictures of what develops. I am really hoping I can find an alternate solution to these issues.
I have a 2003 S Type 3.0 and I am replacing the front Struts. My question is do I have to unbolt the Upper Control Arm "A" arm bolt and/or the Stabilizer link below to swing the Strut assembly out. Or can I just unbolt the lower Strut Torx bolt and the 4 upper nuts and snake the Strut assembly out. Just don't want to do more work then I have to here.
Thanks for the help.
Have you had a look at the UK Jaguar forum?
They have a great bushing thread.
The definitive wishbone bush thread
There are 9 pages of discussion and updates. Very worthwhile information!
Discuss - The definitive wishbone bush thread
Poet
10-06-2015 09:40 PM
