Using z max in jaguar engine
Oil goes into your engine..thats it
Received 2,193 Likes
Ill weigh in on this
Engine restore=has worked very well for me on engines with known ring seal issues. Bringing up and leveling compression out as Ive run before and after compression tests
Lucas stop leak products= worked every time Ive used power steering stop lk, oil stop leak hit or miss depending on severity and location
Slick 50 engine oil additive= drove Suburban 60 miles with no water in it as the head cracked. I had a replacement 383 engine waiting to go it so I just drove it home. It was definitly cooking and creaking when I got home. Shut off and engine locked. Let it cool and started right up ran great. While it wasnt out of oil. it was definitly WAY above operating temps
Zmax= I get this stuff at work and have changed oil in the Jag 2 times over the years and added. Then went on 2 different log trips. Both times I LOST 2 mpg avg, changed the oil and left it out and mpg came back up to before. Ive never used since..Nor does anyone else in the shop and its free or depending on how you look at it
I still recommend Lucas and Engine Restore but only due to my personal use and experiance
Cheers!
Received 2,266 Likes
You need to get less gullible or naive friends. It will save you thousands in the long run.
all that zmax//slick50/duralube and all that crap is designed for is to "market" toward ignorance to collect $$$
BrentGardner
28
04-26-2024 03:08 AM
SingBlueSilver
08-27-2015 02:20 PM
