UV tracers compatible with moly power steering fluid
Question for all of you:
My STR uses a Moly type $16.00 per L. (Autozone) power steering fluid. I'd like to trace a leak using UV tracer but want to make sure the tracer is compatible with the Jag style (autozone vs. Jaguar dealer) moly power steering fluid.
Any thoughts or suggestions?
Thank you for any and all input.
first car 1957 XK140 DHC....current cat....03 STR Quartz/lt. gray
911 993
and others
911 993
and others
Re: shout....I'm new to posting and thought that perhaps....if you're just a bit 'visually challenged' (like myself) then, once again, perhaps a larger font would be an act of courtesy.
I here by apologize profusely and ardently to any and all that all that I have or will offend by and in my ignorance to all the seasoned midnight Jag forum watchers.....
Thanking you in advance for you patience and consideration. :-)
Thank you for your input. I really appreciate it. In my rather extensive research I haven't found any information to the contrary. That being said my first car was a Jag and in those days all English cars (at least that I was aware of) required non U.S.A. type of fluids. Hence my caution re: this (just developed) power steering leak. After a 42 year hiatus from Cat Cars....I'm back and have only, what is now, archaic knowledge.
If I've learned nothing else in that hiatus....I've learned that a little extra 'dose' of caution is better than too little.
Thank you again for your input. Much appreciated.
2003 STR, Quartz/light gray inter. 126,000 and counting. (love the car)
911 993 miles? (mucho....a driver not a garage queen)
two wheelers....Americansky and German
and 'Other stuff'
and 'Other stuff'
kmdakane
03-05-2016 03:13 PM
Jaguar Forums Editor
Jaguar Press release
03-02-2016 09:38 AM
03-01-2016 11:48 AM
