V6 head gasket?
V6 head gasket?
At first I thought I had a coolant leak but it was blowing out of the cap .
I am hoping I am wrong but am getting bubbles through a tester when I run the cold engine so it sounds like a head gasket sending fumes into the coolant.
Has anyone done a HG replacement on a V6 or had one done at a garage?
Would it be worth retorquing the head bolts? The rest of the car is good and it runs fine so I reckon its worth doing.
Please run the proper test first!! Any parts store will have a tester to check the coolant for combustion gases. The V-6 is not known for head gasket leaks and is pretty rare.
So;
First test the coolant
Second if combustion gases are present then re-torque the heads in hope that will fix it.
In my experience if you do have a head gasket problem the gasket will already be burned beyond use and no amount of re-torqueing will fix it!
Please post back with your results.
So;
thommo (01-19-2012)
Received 6,320 Likes
I did the test as advised above and it failed the fluid went yellow showing combustion gases. So I am still hoping that replacing one bad head gasket will be ok .
The testing kit suggests running it on one bank at a time to see which one or both leaks. I am guessing that a compression test on all the cylinders would tell me the same .
I would do it myself if other members think its sensible or pay a good mechanic I know (not a jaguar specialist), Any further hints or tips?
Received 2,637 Likes
Surfacing the heads is always a good idea when changing head gaskets!! In fact I consider it mandatory but it's your choice.
I am a bit worried about his statement that this will somehow affect the cover gasket?? It has nothing to do with how the gasket fits. If you cut too much it will affect how the intake manifold seals to the heads but if you cut just the minimum to remove the warping it's usually OK. Usually a .005" to .01" cut is all that's required. Any more than that I would consider replacing the head.
I have to agree with NBCat here. Did the car over heat? These V-6 engines do not have head gasket problems at all so something caused it. If it did overheat you will be VERY lucky to not have a warped head.
Can you explain the test kits recommendation about "running one bank" at a time?? The test kit was checking the engine coolant correct? That type of test cannot tell you which gasket is leaking.
I never change just one head gasket. If it got hot enough to blow one side the other side was also was exposed to the same high heat. So you are taking a chance that you will need to go back in and change the other one at a later date. Are you selling the car or keeping it?
They are replacing both gaskets and hopefully have checked for warping and found it was straight. The problem was likely from coolant loss as the previous owner had replaced a heater valve and the top up tank. I will know more tomorrow as it should be finished then and I will report back. I hope to keep the car a few years as I recently bought. Now I know why it was cheap and being sold by auction!
X308XJR
05-20-2019 06:50 PM
Woznaldo
09-26-2015 11:02 AM
