V8 4.2 Intermittent Starting Problems
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
My 2003 4.2 V8 S-Type has started to suffer with intermittent starting problems.
Sometimes it will turn over for ages and not start. It can take 3-4 attempts before it actually starts.
Could this be related to the fact when it went to a independent Jaguar service dealer that they used all the fuel and left well below empty when I collected it?
It normally will only do it the first time it is started that particular day. Once started the first time it doesn't do it again.
Gradually over the last month or so it is becoming a little more frequent.
Thanks in advance.
- Start motor?
- Fuel Pump?
- Fuel Filter?
- Cold weather?
- Non Varta battery?
- Not realising its in Park?
Thanks in advance.
You can safely rule that one out. If the computer doesn't think the transmission is in N or P, it won't let the starter engage.
tech.advice (11-08-2016)
Mine does this also and weather does not seem to be a factor . Its done this before when its 90+ degrees out. I did not see that you had started this thread, it is very similar to mine, however it seems to have the same symptoms.
I'm reluctant to take it to the Jag dealer ship because it is intermittent and they are going to charge you even if they don't find anything .
I had this on my first Jag an 01 S type 3.0. Not sure if the result is the same with newer post face lift cars. My problem was the fuel pump. It acted like yours for quite some time. It got worse as time went on and required more cranking to start. Eventually the fuel pump gave out while the car was on the road. Fortunately it was near home and some nice people helped push it off the road. Still not a fun day.
Jumpin' Jag Flash (11-09-2016)
![Icon Frown](https://www.jaguarforums.com/forum/images/smilies/icon_frown.gif)
