v8 s type no heat!
Received 6,361 Likes
Cheers,
kurt beaton (10-23-2011)
Hi, if i leave it ticking over for about 20 min i will get slightly warm air but when you ajust to hot or cold it stays the same temp, as soon as i drive down the road it goes clod........ what do you suggest i do? stick it on a computer will that tell me whats going on
And i suppose flush the matrix through with a hose?
(Head gasket)My mate done a test for a good 10 min and the die stayed blue
Thanks Kurt
Thanks Kurt
Change the DCCV first. When you change it be SURE to use compressed air to blow out the heater core. Then see what you have. Use the Lincoln LS part it is much cheaper. Amazon or RockAuto has it.
Sounds like you might have a combination problem but the DCCV is definitely a wear item and needs to be replaced.
You can check the AUX coolant pump on the bench just don't operate it dry for more than a few seconds. This could also be part of your problem but don't change it yet. Just check it when you change the DCCV. Your in the same area anyway.
Finally has the thermostat been changed and any idea if the coolant has ever been changed?? Is it the correct coolant? Depends on the year of the car.
We need the year and miles on the car for better answers.
No Heat
Hi guys, new to the forum. Hope this helps. My 2000 was having the same problem. When I took it to the dealer they found out that my antifreeze reservoir had a small leak that kept my coolant/antifreeze level below the level needed for the heater to work. I thought they were blowing smoke up my you know what, but after replacing the reservoir my heater startred working perfectly. Hope this helps.
kurt beaton (10-27-2011)
Sorry for the rant.
So to sum up.......lack of heat, or that "gee, I've never heard that fan run like that before" kind of voice in your head; means get it checked out! Even if the temp gauge reads normal.
Cheers,
Well if "Matrix" is a different word for heater core then do what I posted above.
There are 3 hoses going to the heater core and you can unhook them on the passenger side of the engine compartment for USA cars. Then use compressed air to blow everything out. Don't use real high pressure or you might damage the core. Use about 25-30 psi air pressure.
I don't understand missing a hose? Can you explain or post a picture? The S Type has a good number of coolant hoses and they all go to something!
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
