Vac Leak
Ok, I am trying to chase down a vac leak (I'm assuming) as it keeps throwing a code for lean bank 1& 2 with a restricted performance light. I have checked the vac lines on the brake booster and the one that is attached to the pass side valve cover with no luck. Are there any other lines? I pulled off my airbox lid to make sure it was seating correctly, and reattached my intake tube with no luck.
Mike, check: 1. EGR tube to passenger exhaust manifold 2. connection at intake manifold where brake booster vaccume line connects. 3. pre-cat exhaust leak. 4. gaskets that connect charge coolers to blower. 5. hose from intake tube to driver cam cover 6. throttle body gasket 7. vaccume lines going to intake manifold at rear of blower (grey w/black stripe). 8. the torqueing of the engine can rip the rubber connectors at the clamps for the modded air intake tube. 9. loose cam cover will cause a crank case ventilation vaccume leak. 10. intake manifold gasket leak. 11. cracked evap. canister. A smoke machine really helps show the leaks.
Michael Star (01-28-2013)
Michael, as I recall the guy down south that ripped Seth off helped a fellow STR member with a vacuum leak that was caused by the Purge Control Canister crack at seam. I recall just a few that have cracked seams to me more on the V8s for some reason.
I know I have posted a granny V6 picture but its the only one that I have. Notice the red PCC in right hand of picture:
hafren
09-07-2015 10:30 AM
