Vaccum Leak
I have a 2001 S-Type Jaguar with the 3.0 V6, which has a vaccum leak. The problem is I don't know the part number of the hose or what it's called but I can discribe where it's located on the engine.
There is a tube that comes from the throttle body and goes toward the back of the engine (toward the firewall). The tube goes into a 90 degree rubber boot/tube that seems to connect to the engine just behind the intake manifold. It's the rubber boot/tube that has a large hole in it and needs to be replaced. I can hear the vaccum whistle when the car is running and if I place my finger over the hole I can feel the vaccum pressure.
Thanks bfsgross for the vote of confidence, although I am by far no expert
I am with JagV8 on this MYs 2003 and up are different from the preface lift 3.0s. I would only be taking a stab that it is either the pcv vacuum line or the pcc (purge control canister) vacuum line.
Here is a thread that may point you in the right direction, BUT its for MYs 2003 and up:
https://www.jaguarforums.com/forum/s...ics-faq-52720/ you may or may not be able to veiw the pictures being a new member sooooo, please follow JagV8s advice and post up an intro in the "New Members" section.
Welcome to jaguarforums.com
capitaineInsano
10-03-2015 02:22 PM
Johnken
09-22-2015 03:53 PM
