Vacuum Leak
Vacuum Leak
When SWMBO got back from picking up the eldest at the airport her 2000 3.0 S-Type was showing P0171 & P0174. I can hear the leak. If I disconnect the breather at left rear of the engine the leak stops. It sounds as if it is coming from under the manifold so I am thinking PCV replacement. Sound correct?
I haven't had the manifold off for about 40K miles, so I am thinking coils, plugs, and PCV. What else should I replace while I have the manifold off - the car has about 135K miles.
Thanks,
Steve
Thanks,
Steve
Welcome to the forum. There are a few things that you will need to do prior to becoming a full fledged member. I don't know if you will be able to view the link I provide but with in it you will find the answers to your questions.
Here's the link:
https://www.jaguarforums.com/forum/s...ics-faq-52720/
Here's the link:
Correct, but... In the first paragraph I provide a link to Gus's site ( JagRepair.com - Jaguar Repair Information Resource ) that explains in detail and pictures how to replace the "under intake elbow".
There is only 1 rubber hose elbow under the lower intake.
Received 2,637 Likes
The following 2 users liked this post by NBCat:
abonano (10-03-2016),
Jumpin' Jag Flash (10-03-2016)
We will just have to disagree on that, in my life I have seen far too many aluminum heads have the threads damaged by using anti-seize and then over torquing the sparkplugs (using the manufacture's spec). And it is a problem that keeps on giving as the next mechanic may not use anti-seize but there is enough left to strip the threads at the specified torque. But we are getting pretty far afield from items under the manifold.
Steve
Steve
FWIW I recently completed what you are anticipating doing. I also changed my IMT O rings and my valve cover gaskets.
Also I had a vacuum leak at a rubber adapter at the left rear of the manifold. It was rotted a lot worse than the elbow underneath the plenum.
Search for my thread. One of the pictures has an arrow pointing toward the other adapter I had to replace. The part number is also in the thread if needed.
Good Luck!
Good Luck!
If you mean the one at the left rear of the engine on top of what I think is an oil separator - that is where I first though the problem was. Unfortunately it is in excellent condition. I'll look up your thread, part numbers would help since I am 2.5 hours from the nearest Jag dealer.
Steve
Steve
I have an excel sheet that I converted to pdf I got from the Cadillac Lincoln site with step by step instructions that were awesome to get me through the removal of the plenum, and down to the bad elbow. Surprisingly, Ford charged the most for the replacement, a Jag store in California turned out to be the cheapest, use the part number and description, include in " marks "s-type" and you'll get better goog results. if you use the - key as, in s-type, google thinks that's a removal of the word "type" from your search function. If you want the pdf message me and I'll get it to you.
troepie (01-16-2017)
FS[SouthEast]: 2000 Jaguar Vanden Plas for Parts Only
blackhonor9
08-29-2016 03:52 AM
Peter Jones
08-24-2016 08:12 PM
