Vacuum leak elbow(s)? Car stumbles but no CEL
My 2000 3.0 always had a stumble when shifting into 3rd gear, then it got worse and would stumble/stutter at idle, up and down about 50 rpms but never had a CEL. I thought it might be the IMT o-rings and replaced them, it helped a little but not much. I plan to use carb cleaner and check all vacuum lines, in reading a post by Joycesjag about vacuum lines https://www.jaguarforums.com/forum/s...ics-faq-52720/ he mentions two elbows under the intake that are known to leak, a seperate post on jagrepair shows replacing only one elbow, is it one or two?
http://jagrepair.com/VacuumLeakSType2000.htm
Received 6,336 Likes
JagV8, the most common elbow that leaks is located under the lower intake as Gus points out in this repair: http://jagrepair.com/VacuumLeakSType2000.htm
The 2nd overlooked, I believe would be the brake booster elbow that is located on the backside or firewall side of the upper intake (or plenum), as Brutal suggests in post 5 of this link: https://www.jaguarforums.com/forum/s...e-today-42429/
BrentGardner
28
04-26-2024 03:08 AM
rusty37
06-07-2016 04:43 PM
SingBlueSilver
08-27-2015 02:20 PM
