valve body spring
Hi, I just took down the valve body from my 2000 s type with 5r55n trans. A spring fell out as I was lowering it, from what I understand it is called the main spring. The problem is I can't figure out where it came from, there is a hole where it looks like it should go but I hate to put it back together and it be screwed up. I followed this link HERE and it warns about this but doesn't say where it goes..any help would be awesome, thanks
Received 6,327 Likes
See if these help,
http://www.sonnax.com/system/instruc...947J-S2-IN.pdf
http://www.sonnax.com/system/pdfs/11...pdf?1289926275
http://www.sonnax.com/downloads/valv...Ford-5R55N.pdf
No did'nt lose the ***** and there is actually 3 ***** in my valve body, 2 on the edge next to eachother and one kinda towards the middle. As for the main spring If you look up at the trans with the vb down there is a hole with some kind of brass fitting inside. It is the only place it could naturally go. It's towards the back by the big circular part called the low/reverse servo (i believe)
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
xjrjag
09-27-2015 01:53 AM
Tar
09-06-2015 11:24 AM
