Valve Cover/Cam Cover Gaskets
Getting ready to replace the gaskets tomorrow evening. I read on another forum that a specific silicon sealant is needed to attach to gaskets? Also said there is a sequence for torquing the bolts back down? Any input? Also read that the throttle body has to come off for the driver's side, will I need to replace the gasket when i put it back on? Just want to make sure I have everything ready. Thanks.
What year, what engine.
No specific sealant, I used a top quality gasket sealant and was fine. Cam covers do require a torques sequence and they can be found in the cam chain tensioner write up. It's a jpeg I think. Printed it off for myself a while back.
If you can't locate the PDF via google that has it, ask your dealer to print one of for you. The nice lady at the parts counter has done this for me.
Honestly, I torqued mine per spec but with my other cars I just tighten in a zig zag pattern a bit at a time and I've never had a leak. Don;t let it stop you from finishing the job, it's not CRITICAL to torque it dead on, it's not a cylinder head, you just want the gasket to live and not leak.
Got the new gaskets put on this evening. Not sure if a coil was bad after all. No oil in the area and the boots looked fine. There was oil in the spark plug cylinder in the front and rear plugs on the driver's side. The only bad news was that I lost valve cover bolts in the process from the driver's side. Can I use a similar bolt or do I need to get one from a used motor. Any other makes (Ford, Lincoln)that will substitute. Thanks. I would not have even attempted this without info on the forums.
FINISHED!!
Ifound the lostbolts in the driveway about 10' from garage door.Bolted everything together replaced gaskets, coils and plugs.All for under $300 and about 5 hours work, best of all it worked.My only suggestionfor anybody elseis to remove the bolts completely from the cover before pulling the cover out of the engine.I was afraid to pull on them tomuch because I thought theywere permanently attached. That would havesaved about an hour searching and hoping they didn't fall into the engine. Thanks for all the help.
1964Daimler
09-09-2015 11:20 AM
