Valve cover loosening sequence.
Hey all,
Getting ready to change out my cam cover gaskets and spark plug well seals etc. In looking in JTIS, i found the tightening sequence (see attached photo). would the loosening sequence mirror the tightening sequence or would it be reverse order?
Also, on the RH side cam cover is a circular part that bolts to it. The second attached photo only calls out the PCV pipe but when I do a search for the PCV valve it doesnt look anything like the circular part pictured. I ask because sometimes in cold start I hear a loud whistle vacuum leak coming from this part and need to replace it or at least get a new gasket for it. problem is i dont know what it is to buy it![Icon Goofygrin](https://www.jaguarforums.com/forum/images/smilies/icon_goofygrin.gif)
Thanks again for your help guys.
I helped a friend do the vvt and chain guides update on his V8 and all I can say is be very careful with any of the plastic stuff like that ventilation piece you made note of. We had a Jag tech helping us and still had a lot of the plastic connectors that just snapped. They get brittle with age.
Hey all,
That big round thing is called a "valve" in the JEPC. Its 2. in the picture. Updated part number is AJ87773. It is $39 from Direct JPLV Porsche Parts.com.
However, the leak could be coming from the hose that attaches to it. 1. in the picture. Updated part number is AJ811728. It is $66 from Direct JPLV Porsche Parts.com. Ouch!
Jagmansstype (12-29-2012)
Based upon the experience I had with these plastic bits (I actually never touched any of them, the Jag tech broke everything) I wonder if the following might have made things go better:
1. Try really hard to find out exactly how the connectors come apart before touching them. Trial & error led to mostly non-recoverable error in our case.
2. Maybe preheating the connectors and hose with a hair drier (not a heat gun) would maybe them more forgiving?
3. Then spray liberally with WD40 let it soak in and re-heat them.
Be prepared to replace them though.
What ever happened to steel & brass fittings with decent rubber hoses?
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
xjrjag
09-27-2015 01:53 AM
Dickie_L_J_O
09-13-2015 07:44 AM
