Vanity mirror cover 2003 STR
Get a small roll pin approximately the same diameter as the broken plastic pin,then drill a 1/16th in hole through where the plastic pin broke off(completely thruogh).Enlarge the hole in small increments until the roll pin is a tight fit,then position the visor mirror door in it's opening on as though it were open and insert the roll pin from the inside outward until you feel resistance.Back it off a hair and put a dot of super glue(gel works best,as it doesn't run) on the inside end of the roll pin to keep it from backing out and you'll find you've got a permanent fix.
When I bought my 2003 S-TYPE 3.0 both of the covers were in thge trunk!! I was just glad the previous owner didn't throw them away!
Gary.
Gary.
clubairth1
29
05-10-2024 12:57 PM
Dimitrigregorio
17
09-05-2019 03:47 AM
kabs3012
09-12-2015 10:40 AM
