Vibration
It feels like somethings is tugging at the car intermittently when the vibration and howling starts. The whole car has the sensation of a slight vibration but I can also feel it in the gas pedal. I also noticed yesterday that with the windows down I hear a high pitch squealing that goes away when I apply the brakes. I'm starting to think that it is a wheel bearing like Envy said. I did have a caliper seize causing enough heat to warp the rotor and maybe it also overheated the bearing. It does seem to be getting a little worse.
I have lived with this vibration I feel through the gas pedal for a couple of years on my 2008 Stype 4.2 for several years. I have changed front wheel bearings but that made no difference. There was no indication of rear bearing wear through movement not the car was not as quiet as it used to be. I am getting close to 200,000 km. so I changed out the rear wheel bearings. It is not an expensive job, especially if you have a buddy with a press and is quite doable on your own. Car quieter but mostly the vibration in the gas pedal is gone.
hen555
09-07-2015 11:13 PM
