Vibration Damper (or Crank Shaft pully) Bolt
Old 01-10-2013, 04:53 PM
DrkNyte's Avatar
Default Vibration Damper (or Crank Shaft pully) Bolt
Hi All,
I need to know which way to turn the bolt for removal. I tried either way but the bolt is on there really tight. I'm guessing this is not "lefty loosie". for removal i think I should be applying "clockwise" force on the bolt. Please confirm.
Thanks,
Old 01-10-2013, 09:54 PM
Received 10,469 Likes on 6,914 Posts
Ummmmm, I am assuming one of the V8's??????.
If so, it is a standard RH thread, sooooo looking at the front of the engine anti-clockwise to release, and they are SUPER tight, and a new bolt is highly recommended. I did the last one by attaching a looooong 3/4" breaker bar to the socket (forget the size already), and resting that bar end on the concrete floor, and "flicked" the starter motor, simple as.
You might want to unplug a sensor, or fuel pump relay so the engine cannot fire up, but I did not, as the key action is a simple "quick flick" and thats it.
Some say it is a rough approach, maybe so, but no harm is done and it's simple.
Re-tightening is a pain, either a big torgue rattle gun, or lock the crankshaft, and heave on a long bar.
plums (01-10-2013)
Old 01-10-2013, 10:38 PM
plums's Avatar
Received 2,181 Likes on 1,621 Posts
Thumbs up
Why not. It's simple and has never failed for me.
RoyLittle0
05-25-2023 02:38 AM
RaceDiagnostics
07-07-2022 06:41 AM
duecedriver
12-25-2015 11:47 AM
tsimms7
09-15-2015 12:43 PM
Tar
09-06-2015 11:24 AM
Quick Reply: Vibration Damper (or Crank Shaft pully) Bolt
