Vibration under acceleration
Guest
Posts: n/a
Hi all
Since getting my S type a couple of weeks ago (54 plate diesel) I've noticed a vibration under light to medium acceleration from about 30mph / 2000 RPM upwards, but strongest around 2000RPM. Seems worse under quite gentle acceleration and is often not noticeable at all when accelerating hard. At a steady speed there is no vibration at all. The car is otherwise very smooth and vibration free. I've had a good search of the forum and can't find anything. Any advice on what to look for gratefully received!
Edit - just to add, it feels very much like when you have a rear wheel miles out of balance, but is not there at a steady speed as I would expect to be the case in this scenario.
Regards,
Dave
Regards,
Dave
Have the drive shaft and carriers checked.... My cousin's 535i did that. It also displayed a shudder when cresting a hill during spring unload. The dealer inspected his drive line and rear diff. Changed the carrier bearing and rebalanced the drive shaft and all was fixed. That was a week after buying it new in 2001 and the problem never came back.
Guest
Posts: n/a
Hi All
Just to let you know, for reference in case anyone else has this problem, that after much jiggling of suspension components and driveshafts this has been diagnosed as a torque converter failure! Turns out that a new (remanufactured) one is not all that expensive, but the six hours of labour is. Luckily it's under warranty!
Regards,
Dave
Regards,
Dave
i was just gonna post that it could be your torque converter
https://www.jaguarforums.com/forum/s...rque+converter
https://www.jaguarforums.com/forum/s...ghlight=torque
jimforrest (uk)
02-28-2019 06:42 PM
2000, acceleration, aceleration, balancing, car, fix, jaguar, light, rpm, shuder, suspension, type, vibrates, vibration, vibrations, wheel
