voice command issues. 2005 s-type
just bought a used 2005 s-type. i am having problems with the voice command. when i have the music on and hit the voice command button all it does is mute the music. there is no beep to let me know that it is ready for my commands. another question i have is this car equiped with bluetooth?
S-taurean (01-26-2012)
i emailed jag and got a reply the next day with everything my car had fitted to it, even the type annd color of the wood !!!!!
if the button does nothing when no music you don't have voice, i think you might be able to install the voice module but not 100% sure, someone on here will know for sure
Thanks for the reply to the both of you. Is that an option that I can be installed, and would I have to replace my navigation system to have it installed? I would think that if it was equipped a navigation system that it would also have voice command. Shows how much I know
Second, yes, you can add Voice, it's just a salty proposition. The attached bulletin lists what is needed.
Cheers,
As I recall, adding JaguarVoice to my 2005 S-type 3 cost about $700. It takes a module and a cable. It doesn't disable the Nav unit. All this stuff is on a local area network and the JagVoice unit is just one more "subscriber" on the LAN.
Biggest difficulty I have is remembering all the commands. My wife drives the Jag everyday so when I drive it there's a lot to learn all over. The module helps. Press the button and say, "Help" and it will provide a "top-down" explanation of the commands.
S-taurean (01-30-2012)
JAGUAR XR834964 MODULE/VOICE (QTY of 1 Jaguar parts), JAGUAR OEM PARTS
OH this is a bit better but not enough ...
http://www.carpartsestore.com/prodde...?prod=XR849645
Thanks for posting this but O U C H!
JAGUAR XR849645 MODULE/VOICE (QTY of 1 Jaguar parts), JAGUAR OEM PARTS
Toad Ya!!
