Waking the cat
Waking the cat
First time poster here, I have a 2003 S Type with 48K mi on it. It has been sitting for 10 yrs. in my garage, I live in So Cal. Long story short, the water pump went out and wasn't able to fix it at the time, until now. I have to be able to start it to get it out of my garage so it can be towed. What do I need to do to do safely? Aside from the mentioned water pump, what can I expect to need to have replaced due to it's long inactivity?
Received 2,677 Likes
Remember to post an introduction on the New Member Area to receive a proper welcome to the forum.
Which engine is fitted to the vehicle?
Here are some items to work on if the vehicle is being prepared for use after ten years:
- All fluids must be replaced and the fuel system drained and flushed.
- The fuel pump should be replaced as they tend to seize if the vehicle is left unused for extended periods.
- Fit a new battery
- Replace the tyres
- Inspect the engine compartment and wiring looms for evidence of rodent infestation and or wiring loom damage
engine is a 4.2L V8, thank you for the info. Rodents shouldn't be a problem but I'll check anyway. For the fuel pump, I did some reading and was wondering, would I need to replace the whole thing or just the motor inside. Saw a video on this, however I know quick and cheap is not always the way to go, but these things are kinda expensive.
It is tough to put a dollar amount on something like that. This video may help explain the estimating process:
https://m.youtube.com/watch?v=yMf5dvUlYko
HHAHAHHA!
kert1224
20
11-07-2014 01:41 AM
