water heater valve
Old 02-18-2008, 01:37 PM
steeley123's Avatar
Default RE: water heater valve
thanks
Old 02-18-2008, 01:42 PM
steeley123's Avatar
hi
if it needs to be programed do i have to take the car to a jag dealer or can anyone do it
thanks
Old 02-18-2008, 02:07 PM
dealer has to do the program..
Old 02-18-2008, 06:21 PM
Ok, check these wires on back of climate panel -
FC27-06 and FC27-05
Only test these on Hi setting and Lo setting. Anywhere inbetween will be futile.
Ok Connector FC27 will be the grey 26 way connector, not the grey 22 way. Will be on the top row, right next to each other will be Pins 5 & 6. Pin 5 will be Brown with Blue stripe, Pin 6 will be Brown with Green stripe. Same as before. Should be ground on high and battery voltage on low - vehicle running. If you have battery voltage all the time, you can touch the wire from one of the pins to a ground. If the car starts blowing hot air on one side or the other, you know for sure module is bad. In the trunk by spare tire, there is a white label. It has letters and numbers. Look for the one that say CCM or ACCM. Look at the numbers beside them and write them down. Probably something like LJA2299AC/001. If you go to junk yard go to one you can pull the part yourself and look at this label first. Must be the same number or will not work in your car.
Good luck and keep us posted.
Old 02-19-2008, 12:56 AM
steeley123's Avatar
ok will do all that and let you know out come once again thanks for your help fingers crossed
steeley123
Old 02-19-2008, 11:50 AM
steeley123's Avatar
hi mate
tried all the things you told me and got a big fat zero tested the wiring as you said and ground it as you said and nothing happened
thanks paul
Old 02-19-2008, 11:52 AM
steeley123's Avatar
steeley123
titleAndStar(17,0,0,false,",")
Starting Member
[align=center][/align]
Status: online
hi mate
thanks paul
_____________________________
steeley123
  #28
Old 02-19-2008, 12:28 PM
What were readings on those wires hot and cold?
Old 02-19-2008, 12:41 PM
steeley123's Avatar
no change 13.75v
  #30
Old 02-19-2008, 06:12 PM
Then definitly control panel is bad. It is putting out voltage which means it is working just not how it is supposed to.
You have now performed a thorough and approved jaguar diagnostic!
Now get panel replaced and you should be good to go.
Sorry it wasnt something easier.
  #31
Old 02-20-2008, 03:38 PM
steeley123's Avatar
hi mate
thanks for all your help with my problem will do what you say and order the panel from jaguar will let you out come once again thank you
paul
  #32
Old 02-20-2008, 06:28 PM
No problem, remeberb to get the number off label in trunk, also when you order, maybe take panel with you to dealer. Justto make double sure you get right one.
  #33
Old 03-03-2008, 06:17 AM
Any update?
  #34
Old 03-04-2008, 02:29 PM
steeley123's Avatar
Hi
got panel. fitted it. still got no heat.Ihave a auto electrician coming on friday as i have now given up and fear it maybe more indeph and out of my league. cheers will let you know out come
  #35
Old 03-04-2008, 06:05 PM
did you disconnect battery again after the install of panel? You need to do this as vehicle will still see a problem.
  #36
Old 03-07-2008, 02:57 PM
steeley123's Avatar
hi the auto electrician came today he told me that the thermostat was faulty so i removed it and tested it and it was, so i got a new 1 and fitted it and also got a top hose and fitted that and i removed the live of the terminal to do a reboot. AND STILL NO HEAT, it's now getting to the point wear i feel a swanvesta and a gal of petrol might get it warm (no) i'll phone the auto electrician again and tell him his job is not done. unless you have some other tricks up your sleave.
  #37
Old 03-07-2008, 06:09 PM
When the car is at operating temp, what is the temp difference in the hoses, before the water valve and after the water valve?
The idea behind that being, is coolant circulating properly? Also, did you check the fuses? If you need to know which ones let us know. Possible the climate panel - the old one may have blown the fuse. Sorry you are having so much trouble.
  #38
Old 03-08-2008, 11:05 AM
ive also had garages change the valve and hook up the hoses wrong.. and i had to figure it out.. his heatercore can still be faulty.. i play with s type heat problems all day
  #39
i love it and hate it at the same time lol
  #40
Old 03-08-2008, 11:27 AM
I could be rich doing 2000-2002 S-Types. Love em. Heater problems are normally easy, but hard to diagnose on here. We know where to go and check but explaining can be tough.
Quick Reply: water heater valve
