Water Pump
Old 06-01-2011 | 03:26 PM
trauch's Avatar
Default Water Pump
Here is post #2.
In addition to needing to replace the ac compressor it seems I need fireplace my water pump.
I know the pump itself is only about $45 but was wondering if the replacement is a job I can do myself.
If so, does anyone have detailed step-by-step instructions?
Thanks.
Old 06-01-2011 | 03:30 PM
joycesjag's Avatar
Again it would help if you put your vehicle details in your signature, ie..year,engine size, model
Old 06-01-2011 | 03:36 PM
Jon89's Avatar
I didn't know that there is a fireplace in the water pump. When I pop the hood to check fluid levels this weekend as usual, I'll have to remember to look for a miniature chimney....
Old 06-01-2011 | 04:25 PM
trauch's Avatar
Sorry, I meant to say that I need "to replace" the water pump.
That's what I get for testing while driving.
This is for a Jaguar S Type 2000 3.0L
Old 06-01-2011 | 04:48 PM
joycesjag's Avatar
I would then replace both the water pump and AC compressor at the same time. Simply because you will already have removed everything to get to either or, aisde for a couple of radiator hoses and to drain the coolant.
Wahooesprit
12-23-2019 03:01 PM
Ozzy_UK
45
02-19-2019 03:05 PM
Ozzy_UK
General Tech Help
01-14-2016 03:52 PM
ksjaguar
11-03-2015 11:14 AM
picard
10-12-2015 12:56 PM
