WDS Question
Actually two questions:
1. Can anyone tell me the pinout for the dc power power cable (a-204) for the wds. I think it is the 3 pin square one. I need to fabricate a cable and dont want to trash the unit by mis-wiring it.
2. Does anyone have a cable to connect the wds to a 2003 Jaguar S type.
Thanks in advance.
Thanks in advance.
Steadicam
The 'A-204' Connector 10 pin layout is as follows:
BACK
X-
XX
FRONT
X = no connection
- = negative
+ = positive
I have attached a pic of the top of the PTU with the 'A' connector.
There is a WDS A-204 cable on eBay now.
Ford Rotunda WDS 418-F232 adapter cable A-204 DC supply | eBay
The OBDII cable needed for Jaguar is the B-203
I have a B-280 cable that will not communicate so it might be for Mazda or some Ford Truck.
Contact me if you have anymore questions.
bob gauff
BACK
X-
XX
FRONT
X = no connection
- = negative
+ = positive
bob gauff
steadicam (06-02-2011)
Bob, If you have occasion to have the Ford software loaded up and want to check out the B-280 cable, I could bring either/both of my trucks round to see if it communicates. Just holler...
Zane
I had a buddy that needed to configure a climate control panel to a 2005 Ford sedan (Town Car ??) and he asked to use my WDS. The B203 would Not communicate so I pulled out the B280 cable and told him to try it (it worked). The cables are different but I don't know the specifics. I don't have a B259 so I can't comment.
The Jaguars only used the B203 but I had the B280 because I bought a Ford WDS and it came with it. I loaded the Jag software on a different HDD.
I don't know what the Aston Martin uses as I have never had one to try the WDS to communicate with.
Anyone use the WDS for AM????
bob gauff
bob gauff
Hello all
I need the Aston Martin diagnose software that works with the IDS/SDD.
I am trying to recalibrate my 2002 Vanquish ASM unit .
I tried at the dealer , but they really did a very bad job and did more harm than good.
my problem : the car goes into R , N , 1 , 2 Gears , but when i go 3rd , it just rolls into N again.
I do have the IDS / SDD system , and as i understood that the AM software would work perfectly with the hardware , all what is needed is the software to be added.
any help is mostly appreciated
regards to all and thanks in advance.
