Weird electrical issues
Hi there,
I'm having these weird issues with my 2002 S-Type
(the one with the updated interior).
Most of the time the driver switchpack (the window and seatcontrol buttons inside the driver door) doesn't work at all so I can't open my window. When I turn off the engine and wait about 10 sec. & restart it, it usually works for about one 1 minute before I need to restart it again for the controls to work.
Also my rear parking sensors don't work - when I start the car there is a loud beep for about 10 seconds but several OBD readings don't show any error codes so for now it's impossible to find out if the sensors are broken or if it's the control module.
Has anyone dealt with this as well or does anyone have some notion of where these issues could be coming from?
Thank you very much in advace!
Received 2,637 Likes
FranklinK (12-20-2018)
Hi there,
You confused me a for a moment there with your first problem until I remembered that the door switch pack includes the seat memory buttons. A quick test to see if this particular function is working properly would be to set two positions in memory and, when the problem with the window occurs again, stop the car and press memory button one and two to see if the drivers seat moves to the positions you preset. If that works then its unlikely to be a pinch or break in the door wiring loom to the switch. The next step would be to remove the switch pack and check for damaged or corroded connections to the switch pack itself and the loom connector. If not then then the problem is likely to do with the power supply to the window regulator motor. You'll need to remove the door card, etc. to investigate further.
Regarding the Rear Parking Sensors. These are a perennial problem and can be adversely affected by the use of power/jet washers. To test that sensors are working; start the car and engage reverse gear with the parking brake set - it may be wise to block the rear wheels if you'r doing this alone - exit the car and get your ear as close as possible to each of the sensors in turn. If the sensor is working you should hear a quiet clicking/ticking sound. If not, that particular sensor is potentially dead or there may be a problem with its connection to the control module. If you hear nothing from all the sensors then its likely that the problem is centred on the control module which can be found in the boot/trunk however it could also be that the sensor loom has been damaged before the first sensor in the series. Check the control module first to make sure that all connectors and wiring are clean, dry and free from corrosion - clean and repair as needed. If you know how to use a multimeter and have access to one you can also do a pin test to make sure the module is getting power. If none of this works get a garage to test the control module for you, it may be dud. If work is needed on the sensors, either to check and repair the cables, connectors or to replace them I'm sorry to say the bumper has to come off.
S Type ownership is such fun aint it.
Hope this helps.
Cheers,
Cubist
Solarus
12-10-2022 05:42 PM
blaksplash
12-28-2009 08:30 PM
