Weird issue
Weird issue
So my s type 3.0 2001 managed to start somehow after a cascade of fixing it. I don’t know what I did but as soon as I start my car the battery lights go on and everything shuts off. My engine still runs however it’s just all the electrics shut off; my speedo and tacho goes to 0 and all my gauges are gone and none of my consoles work. Maybe it’s the alternator but I don’t know.
Several thoughts:
Please give us a quick rundown on recent vehicle history. You've had several threads going and I can't remember exactly what has been done. I vaguely remember new head gaskets and a new alternator, but am not positive.
If the alternator is new, most aftermarket brands won't communicate properly with the car. It will charge just fine, but the little red battery symbol stays illuminated.
Please make sure the battery is fully charged before doing anything else. This is VERY important. Your description sounds like a dead alternator and a partially discharged battery. When voltage drops low with the engine running, most non-essential functions (gauges, for example) are shut down to save energy for ignition and fuel delivery.
Check the alternator output. On an early model, you should see about 13.5v at the battery.
I had some similar weird stuff going on with my 2.5 V6 last year.
It was a poor battery connection on the earth lead.
Previous owner had fitted a battery clamp that looked like it came off a tuc tuc.
Looked ok connection until I loosened it and took it off to clean it then the clamp fell apart.
Got a proper battery clamp now with quick disconnection without removing the battery clamp.
kr98664 (01-29-2019)
Thank you for all of your replies. I’ve replaced the head gasket and exhaust valves. Battery doesn’t look discharged but it could be better. Alternator seems fine too as it does spin and produce some sort of current. Battery cables sound like the problems because of prior issues and horribly designed clamps. I’ll definitely replace those as soon as the weather gets better. Thanks
do you have a way to read jaguar specific codes....the car electronics protect themselves for an over or under charge....18 volts is definitely over as S-Type Owner stated....an over voltage will set a code in a few modules I know because it happened to me when my alternator went bad...luckily I was in the driveway, and the same thing happened...all sorts of strange lights and the car shut off...I ended up being able to re start and got 18.5 volts reading and replaced the alternator with a used oem one.....there are a few different alternators that will fit these cars, so you have to get exactly the same jaguar part as the old one.....especially if it has the "smart charge" system
xjrwithproblems
19
11-18-2014 01:28 PM
