Welding required for mina exhaust
Nope. Two clamps hold the rear silencers onto the pipes, same as the factory design. The tips are clamped on using band clamps.
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/7212d1294610990-welding-required-mina-exhaust-st-exhaust-kit-2.jpg)
I suppose you could tack weld them if you chose, but it's not required. It's a reasonably simple bolt on. I did one for a friend. I don't know what part of Jersey you're from but if you need help let me know.
Take care,
George
Take care,
George
I have installed what I was told is a MINA set of boxes. Yes the are a bolt on in place of the factory mufflers deal. I am not sure if mine are really by MINA because they look identical but don't have MINA etched on the tips. Plus mine came as one piece units but the last picture I saw of the MINA setup had weld on tips like you said.
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/7213d1294611577-welding-required-mina-exhaust-jaguar-s-type-r-mina-exhaust.jpg)
Your pipes look smaller - the current mina exhaust doesnt have the flange to slip over the midpipe like the stock pipes do, the entire pipe to the muffler is that diameter. And the hangers are pre-welded. Did your have the big clamps that went all the way around the muffler that had the hanger on them?
The current mina exhaust also has 4" tips, yours appear to be a bit smaller (more like 3").
Take care,
George
hmm look different than those on the website.
could it be for different car altogether? as far a know they only have 2 type for the Jaguar S-type.... regular and the STR.
did get those mufflers from the Mina Gallery?
Listen to the car with the mina exhaust. If you want it louder then remove the resonators (Hint replace with a mangaflow X pipe, adds power), but it's gonna be LOUD with a free flow exhaust and no resonators.
Take care,
George
George
i had a real loud beast earlier... but i revert back installing a mufflers on the STR.
i had mine without the muffler when i purchased them from a jaguar dealer... it had a stock resonator with 4" tail pipes... really nice looking and sound superb.. but unfortunately the Mrs... doesn't like it.. too loud.
i had a sound clip before i install the mufflers
http://www.youtube.com/watch?v=Zg8570NvlPM
let me know what you think..
George:
I got the boxes on EBay and they were sold as Mina. But as I said before there are no markings of any kind on them. I measured the tips and the ID is 3.5" and the OD is 4". The pipe diameter is larger than the stock STR ones I removed. In fact I had to use a spacer in the expanded section so the clamp would fully tighten down. They came with very nice all stainless clamps you can see in the picture. Seems to be a higher grade of stainless steel than the factory exhaust system. The factory stuff did not stay shiny and got a bit cloudy/corroded on the surface. These have stayed shiny for the year or so they have been installed.
They must be for the STR because they fit very well. I did adjust how the tips fitted in the bumper cutout. They were slightly pointing "in" towards the center of the car. I bent them very slightly open trying to center them in the cutouts. It's pretty close but still just a bit out of center.
George:
The supposed difference between the S-Type and STR exhausts from mina is the size of the actual mufflers. Supposedly the STR one has larger mufflers (probably to quiet it down relative to the smaller displacement cars).
Are your clamps physically attached to the pipe, or are they separate.
George
George;
They came complete, no welding at all, and the hanger is not visible but is also stainless and welded to the pipe. If you look at the end of the pipe where it is expanded out you can see the clamp. It is slightly movable but kind of spot welded in place so it can't be moved very much. These are MUCH smaller and lighter by at least 10-15 lbs per side compared to the stock STR mufflers.
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
Woznaldo
09-26-2015 11:02 AM
