What kind of oil do you use?
#61
#62
Yep, oil and oil filter change is easy on the S type with the drain plug and filter being reasonably accessible unlike many other cars where the design engineer make it almost impossible!!
I tend to change both twice a year using a good quality 5W/30 Synthetic oil and genuine Jaguar oil filters which are remarkably cheap here in the UK
#63
Guys I need your opinions on this K&N oil filter. Some people who are very **** about only using OEM parts will not like this but the reviews I read so far on these K&N oil filter are excellent. Main advantage is that its dam easy to remove with a 1" wrench and autopartsdealer.com are selling them at a discount of $8.67, just check it out and read the overview of it and get let me know what you think???? ![Icon Duck](https://www.jaguarforums.com/forum/images/smilies/icon_duck.gif)
link
http://www.autopartsdealer.com/kampn...p385883-p.html
link
#64
#68
#69
If you want more performance then read the threads about that as there is a ton of helpful advice in there. You need quite a lot of $$$, it cannot be done on the cheap on these already high-performance cars.
#70
Out of curiosity what is the usual killer of the S-Type engines?
#71
Received 2,263 Likes
#72
Over here it appears to be scrapping them due to a repair that's (perceived to be / is) uneconomic. (Crash, MoT - our I/M - etc.) The repair will only sometimes be engine-related but I don't know if anyone even collects data.
Maybe a tech will comment, though they probably don't see most of the scrapped cars.
#73
Jag 79
I do have a K/N air filter. I just put it in the car about 2 months ago. To tell you the truth, I don't notice a huge difference, but I like them pretty well. I have 20 years with them, so I know not to overoil them when it comes time to clean them. That's key with the Jag, as it will screw with the mass airflow sensors and whatnot.
I notice the biggest difference when I open the throttle up. It growls a little louder.
#74
Hey guys is it normal for the brake light to be on after starting my car? For instance after my car is starting I see the brake light icon on my dash. When I put it into "D" drive it goes away. is this normal for all S type R jags? I can see I have less than half an inch of pad left for my brakes, could this be the warning sign? lolz..... Anyone have any suggestions on what brand brake pads I should use to replace my front worn pads with on my 03' S type R Are EBC's any good the red color ones???
Thanks all!!
Thanks all!!
#75
Thanks all!!
Thanks all!!
I sometimes get that on my car --- the brake light. My brake fluid level is normal. Unless your fluid is low or the light comes on during driving, I wouldn't worry about it too much.
On the subject of pads. I put Akebono ceramics on my front rotors. They are quiet and give off no dust. They cost a little more, but are built in the USA. Others are made in China or some other country. They are the best pads I have ever owned. Pads on the S-type are incredibly easy to install.
#76
I always prime my oil filters too to reduce any wear as you fire it up after an oil and filter change. I fill the filter to the brim and allow it to soak in for a few minutes then top it up as necessary.
On the 3 litre engine it is easy with no spillage as the filter is held horizontally when you screw it in.
#77
I finalized the deal just day before to purchase this 03' STR, drove it from TX to FL with my dad
![Icon Bike](https://www.jaguarforums.com/forum/images/smilies/icon_bike.gif)
![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
#78
Thanks all!!
Thanks all!!
#79
The STR has an electric parking brake so when you are in park it puts it on. Once you shift out of park it automatically disengages it. Put your car in D and push down on the parking brake if thats the same light you are good. Pull it back to disengage and know that all systems are good. Its just a safety thing Jag has with the electric parking brake.
Please help.... I'm having the Projector light problem though from the front headlights.
![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
Last question is the "S" mode, How can I tell if its working and on? I just see the illuminated light where the "S" button is when its on, but is there anything else indicating the "S" mode is activated?
Thanx for the help and to others.
#80
