What is this part called?
Received 6,330 Likes
It's generally called the tank turret and is a very common failure spot.
See this thread (and others if you search) for info https://www.jaguarforums.com/forum/s...ghlight=turret
Replace the entire Upper Radiator Hose Assembly. The plastic gets brittle with age and heat cycles. If you try to fix it, it will come back to haunt you by failing somewhere else on the assembly. I ordered one for $68 off eBay not quite a month ago, part no. XR854920. The seller was Impart Inc. in the Atlanta area, phone (770) 948-8353.
These assemblies supposedly fit the 2003 through 2008 S-Type 3.0 cars, but be sure to verify that before you place your order....
Good luck....
Good luck....
Jumpin' Jag Flash (10-19-2015)
FS[SouthEast]: Parting out 1994 Jaguar XJS Coupe - 6 inline
rama1200
20
12-03-2015 11:00 AM
FS[Western US]: parting out 1999 xj8 vandenplas
bavareze
09-11-2015 01:49 AM
