what to service on my 2003 STR 63k
hi all
ive got a 2003 STR its got 63k on the clock and is due a service. i did an oil change at 53k as well as the oil filter and air filter.
now its time to do the service again.iam an engineer by trade so will do the service my self. im just wondering what should be carried out on a 60k service and a 7/8 year old car and is there anything else i should change?
when should the timing be checked?
when should the gearbox oil be changed?
when should the belts be changed?
etc etc
cheers guys
etc etc
cheers guys
if you havent done the thermostat yet, i would do that. also check the coolant tank too.
new battery if you havent done it yet too. Check the wiring in the trunk floor especially the ground wire make sure it is clean. i know it says the lifetime trans fluid, but i would change that. i cant think of anything really other than normal stuff, maybe inspect the main belts too.
gregstar (05-25-2011)
clubairth1
29
05-10-2024 12:57 PM
aholbro1
08-05-2021 05:02 AM
Dimitrigregorio
17
09-05-2019 03:47 AM
Ipc838
09-13-2015 03:27 PM
