What is this and where does it go? S Type 3.0 1999
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/jag_contact_004_1630b6403a09224fd23e0c107b129bc5486d81c6.jpg)
Its resting on top of the rad,2 wires going in ,none coming out ,what is it and where does it go, could it cause a misfire from time to time ,i cannot get fault codes ,is it ok to drive the car with the OBD2 connected? as the engine check light goes out when it stops missing and i cannot get my scan tool to tell me which cylinder is missing , i bet its bank 1 and i did that 2 years ago .. £750 i have given up, drive away with a longish MOT and loads of new parts fitted last week.
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1120x2000/jag_contact_005_fe3d37724f3bb22a50166971e2e8e9bc570f0485.jpg)
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/jag_contact_008_005570d8fbfd1d43d760f224654f8de2c44d8b81.jpg)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/jag_contact_007_be8b54c20e53580115d84a1df0c464b13d1417b3.jpg)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1120x2000/jag_contact_006_bbae7873fd7b60662baa0dfb047ff7bdecfebe19.jpg)
Received 2,652 Likes
The following 4 users liked this post by NBCat:
Catfan01 (01-10-2020),
Jumpin' Jag Flash (01-11-2020),
motorcarman (01-10-2020),
Simon Pickering (01-10-2020)
For reading DTCs, use a smart phone with the Torque app to access the PCM via the OBD port by Bluetooth.
Under no circumstances is the vehicle to be operated under conditions that cause the MIL to flash as catalyst damage is occurring.
Find and correct the misfire(s) or DTC P0420 and P0430 are the result and you will need to replace one or both catalysts to pass MoT.
The following 2 users liked this post by NBCat:
Its not flashing ,it just comes on during a load and misfiring ,i cant understand why my OBD says there is no misfire on a particular cylinder,while scrolling through i got "not ready" on H025, CAT not ready and Evap not ready ..could this be an air leak? I used Torque and Bluetooth and still had no spark code appear ,as these plugs were changed 2 years ago along with the seals i suspect a coil on the wrong bank so i want to be 100% sure which plug is misfiring ,,,,Si
kr98664 (01-10-2020)
Elkulichi916
52
05-13-2017 02:33 PM
