Wheel Nuts - Stripping
Has anyone had a problem with removing cross threaded wheel nut? The metal seems so soft that the hex shape has stripped when the Auto Club tried to remove it.
The final suggestion has been to drill out the stud centre, then remove the nut, and replace the stud through the hub and brake mechanism.
Seems pretty extreme to me.
Any ideas?
And a Merry Christmas to all on the forum.
David in Australia
Any ideas?
David in Australia
Guest
Posts: n/a
I had that problam, lucky for me we used a smaller bit and pounded it on with a rubber mallet. but i was looking at doing the dill out if that didn't work. Maybe heat it up a little before you try turning it. kinda like the warm water on the jar trick,
or drill a little bit into the top of the lugnut, thread the whole with a right tighting thread, then put a bolt in the twist off.
You could put the bit onand fill it with super glue let it dry and twist it off. lol
Weld something to itand twist that.
i have lots of stupid ideas. i'll keep going.
Dremil the nut off.
Dremil the nut into an smaller nut.
Eat it.
Make a time machine and kill the person that crossthreaded thatlugnut onto your stud.
i would say try pounding a smaller rachet head onto the lugnut. Make sure you line it up correctly.
Now that i think about it i should have taken a pic of the nut before i pounded it cuz it wasn't stripped it was bowed out. like a little bomb had gone off inside of it. weird ha? guess that means my car is so fast that the lugs explode!!!!
And when ever i take my car to a tire shop they tell me all my lugnuts are loose. you know cuz they have that cover that rattles.
ok well i'm done telling my tire storys.... merry christmas. good luck. BTW studds aren't to hard to replace.
Dremil the nut off.
Eat it.
Received 6,307 Likes
Well lots of food for thought there.
As an alternative to drilling the stud out completely I'd suggest drilling a smaller hole centered on the edge of the nut/stud which will be easier with a small pistol drill you will likely have at home, then you can split the nut with a chisel then knock out the stud.
Good luck.
Good luck.
You folks in here shouldn't feel like the "Lone Ranger". A BUNCH of people who own Lincoln LS had the same problem with the lug nuts. I ended up replacing all of mine on my 2000 LS. Same story with the window regulators. Ford screwed up many of the same items on the Jag S-Type and Lincoln LS, since they were built on the same platform. I happen to be one of the fools who not only bought a 2000 Lincoln LS, but a 2003 Jaguar S-Type. Both are nice cars, if you can afford them............repair-wise. I had membership in LLSOC and there were sources listed for both lug nut and window regulator replacements.
hunter34
19
09-14-2022 11:09 PM
aholbro1
08-05-2021 05:02 AM
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
