wheel studs move slightly when wheel off
hi all , I really appreciate any help here. with the front wheel removed, the wheel studs individually are all solid and sound with no movement and are not loose at all but they will all move together back and forth slightly when rotated within the confines of the stud holes if you hold them and rotate them slightly against the disk . Is this normal.
Are you sure it's not just a loose disc, which hasn't got the retaining washers on the studs holding it tight against the hub? If this is the case, it isn't anything to be concerned about as the disc will pull tight once the wheel is fitted. Some cars have them, some don't.
Jagman 999 (04-06-2014)
hunter34
19
09-14-2022 11:09 PM
innzane
09-02-2015 10:08 AM
