Where can i get an engine for a good price?
Received 2,652 Likes
Good 4.0 engine are becoming far and few between.
Typically you get what you pay for when you purchase a used engine. The lower the mileage the more you pay. The higher the mileage you pay less, but the greater the risk is will break and waste all your time and money putting it in. I personally wouldn't purchase an engine with over 80K miles on it unless I was planning on some sort of a rebuild. As others have posted, the 4.0 engines had lots of problems. Mainly the timing chain head tensioners. It is also very difficult to get any maintenance history for the engine. Was the oil changed, were all the required services done? Either you luck out, or find out a year or 2 later, you purchased a lemon engine.
I purchased a 2003 STR engine off of E-bay a month ago with 75K miles on it. I have already spent over $1K on replacement parts hoping that the engine wont fail after I put it in. I just hope the engine wasn't ran too hard during its life.
Item Approx cost
- Water pump $50
- Oil pump. $200
- Timing chain kit $450+
- New crankshaft timing gears $200
-Valley/throttle body water hose $40
- Spark plug set $50
- Timing cover Gasket $40
- Timing cover crank seal $20
- Head cover gasket $40
- Other water lines $150
- Gates serpentine belt $40
- Oil filter $10
- Mobil Synthetic Oil $40
_____
Not on your engine, but on Mine
- Super charger oil
- Super charger shout bearings.
Intake manifold and supercharger gaskets.
Item Approx cost
- Water pump $50
- Oil pump. $200
- Oil filter $10
_____
- Super charger oil
tonimccloud
19
01-18-2020 01:56 PM
SingBlueSilver
08-27-2015 02:20 PM
Terrance Williams
08-26-2015 11:50 AM
