Where can i get a expansion tank
$150 not too bad for the "R" apparently. It's in here somewhere: https://www.jaguarforums.com/forum/s...-again-144224/
I can tell you from experience to get the best, most expensive tank you can order. The cheap ones will break early and if the lot is bad from China, you will be doing this job a lot. If you find a tank with a manufacturers number REPJ161308, RUN BUBBA RUN. I had two crack in the same place in 5 months. On my third tank and hope this one is from a different lot.
Amazon has them. About 150 each for the good one. Overheating an aluminum part is death to the part in most cases. While you have it out of service, change all the antifreeze. Use the factory numbers to match. Fill it, bleed it, and ride.
Wayne1357
09-25-2018 02:31 AM
XKR_100
01-14-2016 06:04 AM
