Where to look for engine numbers
The "cheat" way is ask a dealer, although that doesn't guarantee your engine is still the one they have on their database.
The location is described (badly?) in this https://www.jaguarforums.com/forum/a...achmentid=2914
Here is a picture of what you are looking for. It will be tough to see with the engine in the car. It's on the left side of the engine block and almost directly behind the engine mount. Look for the big screw in freeze plug. I think it will be dirty so cleaning and a strong light "might" let you read it. Do you have a borescope by chance??
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/4670d1282073538-where-look-engine-numbers-4.2l-sc-long-block-serial-number-stamping.jpg)
Most of the numbers on the side of the block are the alpha/numeric coding for the piston/cylinder and crank bearing/journal sizing info. The serial number (manufacture time/date) is at the front 'B'bank side of the thermostat housing mount hole on many engines. Jaguar JEPC lists the number at the rear of the 'B'bank cylinder head on the bell housing casting area but all the engines I have are not numbered there. Check both places for your engine number.
This engine pictured was made 1997 Nov 19 at 08:39
971119 0839
bob gauff
971119 0839
bob gauff
Incorrect. Here is where the JTIS says to find the engine number. Remember this is for the S Type. Might be different for other models.
Automatic Transmission Number;The serial number of the transmission unit is displayed on a metal label or bar code (where equipped) attached to the transmission casing.
Engine Number (V6);The engine number is contained on a bar code label on the front cover and is also stamped in the cylinder block casting on the left hand side of the engine below the engine mounting.
Engine Number (V8);The serial number is stamped on an engine web on the left hand side of the cylinder block behind the engine mounting. The emission code is also located here, on the transmission flange.
Do you reckon those are the same places as in the Vehicle Specifications?
Here https://www.jaguarforums.com/forum/a...achmentid=2914
KarimPA
09-03-2015 07:32 PM
