white/grey smoke coming from d/s rear block
Hello I have 2000 s type 4.0 with 160k on it.
Upon starting my jag a white grey smoke comes out of the rear d/s hood then dissipates after being warmed up ,really bad after not running it for a few days.I have searched for threads but am still lost .with the hood open I can't tell exactly where it is coming from.It barely drops a drop of oil when sitting.Any help with this would be really helpful I just got out of the military and sort of short on cash to just take it some where and I'm in northern Colorado and the closest dealer is 6 hours away.please help thank you again for your help
Dj
Dj
Hi, sounds like a oil leak coming from the cam cover dripping onto the exhaust manifold - the oil burns upon start up and dissipates causing smoke - the driver's side cam cover is notorious for leaking at the rear lower end of the cam cover as that is a point where oil would pool when the engine is off before draining back into the oil pan.
The 4.0 is notorious for oil leaks from the cam covers - especially at your mileage - the rubber gasket material wears... the oil will drip onto the manifold making you think no oil is leaking cause it doesn't make it to the ground.
Take your hand and run it down the lower end of the cam cover (cool engine) and you will more than likely get a film of oil on your hand. Check passenger side lower cam cover as well - same deal if you find any oil.
You can try and tighten the cam cover bolts (to ensure they are at spec - DONT overtighten) for the short term - but a new cam cover gasket is in order.
My trick is I use RTV on the lower end of the cam cover (you have to also use RTV at the junctions between the head and timing chain cover as pointed out in JTIS)
I would also change all associated gaskets (Spark well, VVT gasket and all cam cover bolt gaskets as well while your in there.
Good Luck and Happy Holidays and based on your screen name - Thanks for your service to our Country!
cbharley10 (12-24-2012)
Received 2,637 Likes
Be certain any tightening of bolts is done with the engine cold as the threads for some of the fasteners will be damaged or stripped.
If you intend to work on the vehicle yourself, first obtain the JTIS manual as was mentioned above so you have the torque specifications for all the fasteners and the correct tightening sequence for the cam/valve cover so it does not get distorted and cause further gasket failures.
If you do not have JTIS use this link and go to page 96 it has the torque values you need.
Link http://www.jagrepair.com/images/Auto...sb_09_2003.pdf
In addition to your posts with thanks, it is also nice to push the little "Thanks" button for those who provided you with some great information.
Thank you for serving our country, Merry Christmas and a prosperous New Year!
You can get the complete valve cover kit on eBay for about $100. Just make sure you order teh kit with both left and right gaskets as well as 4 new grommets and 8 plug well seals...
I also second bfsgross' comments - Thank you very much for your service and defense of our freedoms! Merry Christmas and Happy Wrenching!
davidladewig
09-03-2015 06:32 PM
