Whoop noise
Guest
Posts: n/a
ORIGINAL: erdoc
I have noticed recently on my 03 4.2l jag 45,000 miles the car makes a "whoop" noise when downshifting. It usually occurs around 20-30 mph when I hit the accelerator to pass another car etc.. the car downshifts and I hear the noise. Any thoughts?
Received 2,190 Likes
Received 6,307 Likes
I had the same exact issue on my '04 XJ8 (same transmission in both cars). Car had about $31K miles on it when I bought it and it made the whoop from the day I got it...Solution was expensive (about $500) but covered under warranty. I don't have the exact TSB #, but it involves draining 2Q of transmission oil and refilling with oil + an additive. I also had jery downshifts which was a re-programming of the ECM. Here's the words I got from the work order....
"As per TSB, installed additive and topped up with 2 units of oil-transmission".
Take it to the dealer and ask them to dig out the TSB for the whooping noise on downshifts, they should be able to locate it....
- Tim
- Tim
OK WELL TRIED MY STORY AGAIN AND APPARERNTLY THE FILTER HERE STOPS AN ENTIRE POST FOR THE USE OF THE WORD AS... OR ****, YOU GET THE IDEA,,, WELL NOT ITS NOT EVEN WORTH ANOTHER SARCASTIC POST BUT YES THERES A TSB THAT IF FOR ADDING A TRANS ADDITITVE FOR THIS NOISE, AND ANOTHER FOR HARSH SHIFTING, AND CLUNK WENT ACCELERATRING AND DECELERATING, THOSE 3 COVER NEW OUTPUT FLANGES, ADDITIVE AND CLEARING TRANSMISSION ADAPTATION(LEARNS YOUR DRIVING STYLE) AND A REFLASH WITH LATEST ECU AND TCM SOFTWARE........SO SORRY JUST LEFT OUT MY WIT THIS POST WE'LL SEE IF IT GOES THROUGH THIS TIME
ORIGINAL: timfountain
- Tim
- Tim
The car was bought from Carmax in Dallas. I took it to them a couple of days after I bought it due to rought shifting and the whoop and they didn't have the equipment to do a full diagnosis, so I took it to the Jaguar dealer, whom I paid and then claimed back from Carmax. I have their extended warranty but this claim was covered under their 30 day complete satisfaction warranty. Have to say the whole experience was very positive. I would expect the select warranty should cover it.
- Tim
- Tim
- Tim
- Tim
Guest
Posts: n/a
mbates50 (12-15-2012)
Seen a lot of post about draining and adding this and that, but as long as it's not a mechanical fault thing, I'm OK with it.
Please advise, thanks
