Will a regular OBD II scanner work on stype?
Will a regular OBD II scanner (service codes, etc) work on stype? I have an ABS and Traction light on (after hub replacement) and I have tried clearing them with a standard scanner. It doesn't look like a standard scanner can even get the codes, though it says it is successful clearly them?
Ideas?
Ideas?
By law any OBDII scanner will pull all the generic codes. Now when you get into manufacturer specific codes you may or may not be able to get them. It is hit or miss. With the problem you’re having I would bet it will require a visit to the dealer. You have already tried and it did not work so I think that is your answer.
'regular' OBD scanners will only capture engine and transmission codes, all other advanced systems like ABS, air bags, body modules, etc will require a more significant software/scanner. The autoenginuity scanner is currently the most affordable and effective scanner for the jags standard and enhanced codes right now.
What h20 said.... but also "regular"? Depends which of the multiple protocols it supports (PWM, VPW, KWP, 9141, CAN). (AFAIK the S only uses PWM, 9141 and CAN.)
And... the model year of your S-Type, which you didn't specify
Have a look at the wiring diagrams for your model year car and then you'll see which you may need. (Or just get AutoEnginuity or the like.)
philwarner
09-05-2015 10:05 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
