Window won't close all the way...
The front passanger side window is working properly, but it won't close all the way. It is coming up short by about 1/4 of an inch. I can slide it up to completely close but it inevitabley slides down. Is there a way to adjust the window. It is catching the rubber seal, so it's not leaking and barely noticable. Just annoying for a detail oriented person.
I can't address the regulator issue, however, sometimes the driver's side window would slow, stop and then move down the track. I applied a coat of wax to the window and the window operated as intended.
As a preventative, I suggest applying a coat of wax to problem windows in addition to addressing any possible problems with the regulator and motor.
99xk8guy
06-05-2023 06:28 AM
