Windows
ChrisJaguar (02-10-2017)
Unfortunately....I'd say a detailed study of the wiring diagram is in order. I'm assuming the problem is exactly the same now, as it was before you replaced all the listed parts?
A broken wire in the driver's door-to cabin wiring harness will delete functionality of ALL windows plus sunroof - from any switch including global open/global close. I'm not aware of anyone experiencing a break in a wire on the opposite side and what effects it may have. May want to peruse the wiring diagrams with an eye toward those types of failures.
It is not unheard-of for new parts to be faulty, but I wouldn't think it terribly likely that your new door switch, if defective, would have the same failure mode as the removed one, since they both seem to work "partially" but I suppose all things are possible.
