Windows mist up in carwash
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
When i go through a carwash all the windows mist up and it takes about 10 mins with the blowers on to clear the windscreen (i clear the side windows by lowering and closing them or they would take even longer). the windows don't mist up at any other time even in the rain.
Any ideas whats wrong.
The heating works fine but the aircon is not cold.
Received 2,263 Likes
I assume the moisture is on the inside surfaces of the glass. For condensation to form, the temperature of the glass would need to be below the dew point and the relative humidity fairly high. Possibly the heater plenum is filling with water due to a plugged drain which is then warmed and dispersed throughout the vehicle by the heater fan. The cold(er) glass causes the water to condense.
Just guessing.
Just guessing.
Received 9,010 Likes
If the a/c doesn't work it can't dry out the air, so you're probably stuck with the problem.
Supposedly (and it may well be true) a/c needs using fairly often to keep all the seals and the compressor lubricated or things can fail.
a/c cools to well below zero (C) so should be fine in current UK weather. It's effectively a mobile fridge/freezer (colder than fridge, hotter than freezer).
Also, sit outside a car with basic A/C. When you turn on Def. most times the A/C compressor will turn on as well.. Even in old cars..
regarding the a/c not working, the car does not mist up at all, even in heavy rain and snow ,even when i get in soaking wet it does not mist up, only when i have been through a car wash does it mist up, and it is very heavy thick mist, it takes up to 10mins to clear the windscreen with the heater scorching hot.
philwarner
28
07-11-2017 10:21 AM
blackenedindustries
09-30-2015 10:17 AM
