Windshield Washer Not Working
My windshield washer stopped working about a month ago on my 2005 S-Type V8. Initially I thought I just ran out of fluid, but I bought some today and it topped off immediately.
I hear the washer motor whirring when I press the washer button, but no water comes out. I don't see any leaks, so it doesn't appear to be a broken hose.
Any ideas? By car fixing skills are pretty basic, but this can't be too complicated.
Thank you!
Thank you!
snuffbox (10-11-2012)
You have a blocked line. An air compressor would come in handy.
There is a hose that is connected to the washer pump located under the front (under) pan (passenger side) that works its way up to the cowl then will seperate into 2 hoses (1 for each wiper arm).
Simple fix and no indy or dealer involved.
I have some "Polident"
I know some of you may find this hard to beleive BUT we have owned this Jag for 12 years and never used the windshield washer!.
So I can only blame us for not changing the fluid in the bottle once a year because of the crud that is built uo around the sensor.
When the message appeared I check the bottle nd topped it off but did not cure the problem. I then drained and refilled with a solution of vinega and water and drove it for a day or two, drained it and re filled it, still not working!
I then added some Simple Green and water for a few days same outcome!
I think after 12 years it is going to need more than one douching of polident so maybe something stronger.
I did attempt to remove the bottle but it looked like a PITA, so we just "push the button" and clear the code!
I will report back after the Polident treatment !!!
al_roethlisberger
09-11-2015 10:04 PM
philwarner
09-05-2015 10:05 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
