Windshield Washer Pump Replacement
This is a strange one and I am a bit confused. I am troubleshooting my issue with the windshield washer and I have identified that the Windshield Washer Pump (WWP) is the problem. As I am replacing it, I have noticed that the WWP wires have 12V when accessories are on or when car is running. Furthermore, the Jaguar S-Type 2005 manual (fig 13.1) shows there is no switch between the Front Electronic Module and the Windshield Washer Pump (see below). Previous versions of the S Type had a switch. Hence, there will always be 12V to the WWP with no switch to turn it off.
Does this sound right? Seems like WWP would just run once I wire it in and burn out! What am I missing here?
Thanks, SS
Thanks, SS
Good that you have sorted your fault.
For future reference most of the jaguar electrics work on a switched earth system, not switch live. The 12v positive is live to most items when the ignition is on. It is the earth that is switched on and off.
Unless you know this it can make fault finding appear a bit odd compared to other cars that switch the12v positive..
Mellow
Mellow
jazzwineman
07-14-2016 03:39 AM
garyofnyc
03-25-2016 05:17 PM
MarcN
03-07-2014 05:56 PM
