Windshield wiper blades for 2003 S-type (base, not turbo)
I'm trying to figure out what I need to buy for wiper blades. I'm on amazon
and that breaks it down to products that fit the jaguar stype 2003, but what sizes do I need to buy? I need two and one is longer than the other... do I just get refilled wipers or do I buy entire new blades?
Whenever I turn them on they're streaking and overall ****, so I would like to get new ones, whatever they are.
Thanks guys sorry if it's a dumb question :9
Received 6,310 Likes
I think they are 18" and 24" a search will throw up lot's of threads.
Don't forget to visit the new members section to post your intro.
wiperblades2013 (04-01-2013)
Norri gave you the size.. (LOL I think he is right). If you are in doubt, get a tape measure and measure them. You can buy anything that you like, from Bosch solid Icon blades to just about anything else since your car is "pre" 05 and has washer nozzles on the hood.
I mention this because if you search for threads you are going to actually find a ton...since the integrated nozzle on the 05 and up car is a pain to get a blade to fit outside the factory ones.
But you don't have to worry about that. Any brand will be OK...
The following 3 users liked this post by Blucarman:
No 19" and 24". Please look at the very detailed threads on this forum because the 2003 and up S Type has a painful and non-standard setup. Follow what the guys have figured out here.
It is much more complicated than it should be.
Since you have not searched try this:
https://www.jaguarforums.com/forum/s...ont-fit-18710/
Tbird... the 05 and up are the PIA... the 03 and 04 cars still had the nozzles on the hood like the pre-03 cars...
I personally would get Bosch Icon blades. I use them on all my cars ( now that I don't have my 05 S type ;P ) They are a little more than the others but I get about two years out of a set even in N/E Ohio with work in the lower snow belt.
Please measure yours before you order... Auto Zone lists your car as having a 24" drivers side and a 18" passenger side. The early cars had 22" blades on both sides. So, if both your drivers and passengers side blades measure the same size then you have 22", if not then definitely check the passengers side to see if it is fitted with an 18" or 19" blade. After sizing, like I said, just get what you want in the correct size, you have a standard hook style wiper arm without the nozzle....
BTW, my 05 had 24" drivers and 19" passengers...
Welcome to the crazy world of Jaguar...LOL
Doing the simple math... you will be safe with 24 and 19.....
Received 2,263 Likes
See... they also list 19" passenger side blades as fitting as well... I figure either size fits.. 18 or 19. The fact that you have larger on the drivers side was really all I needed......
Just buy a 24" drivers and 19" passengers and you will be good to go... and, sure the RainX brand is OK as well, just not my personal preference.
