Winter-time for the STR
Hey y'all:
so, my '03 STR is parked for the next several months. I jut can't drive it in the winter here.
So wile it's down, I'm thinking about freshening-up some items. I'd love a little help on the order I should look at, and what I might consider "as long as I'm in there..."
for reference: '03 STR, with 125k miles.
I'll probably end-up replacing the CATS Shocks. Not 'cuz I wanna spend the dough... but 'cuz they need it. I'm looking at a possible lowering-spring while I'm at it. Suggestions? Experience?
I'm going to do the transmission, following the procedure found on this forum for replacing fluid and filter.
I've still got just a little vibration / not-quite-a-miss when the car is cold. I'm thinking plugs & coils? What else should I look at?
I'll probably buy one of the intakes, like Caldoofy's. Or make one. I've already done the flat-panel K&N.
anything else y'all would recommend?
Originally Posted by tbird6
Brutal posted it a while back but if I have to replace any CATS struts I will get them rebuilt by Bilstein. They are the OEM for the CATS struts.
Good call... I'll go search for that thread. I was not aware of this option 'til you posted this.
Originally Posted by michaelstar
How does your coolant reservoir look? What about belts? DCCV?
I assume you put the STR on a Battery Tender or similar device? I also put in 2 small jars of Damp Rid inside the car, as my garage is not climate controlled. I set mouse traps all around too - I've considered leaving the hood open to discourage any little buggers from setting up shop in there, but so far hasn't been an issue.
I add the appropriate amount of Sta-Bil to the gas and run the car for a few minutes as well.
As for maintenance mods, what the others said sounds good to me! Mine will be getting the rocker panels pulled off and resprayed, but other than that, at 43k miles, not a whole lot else to mess with. Cabin air filter will be changed in the spring before i get it back on the road.
Hey y'all:
Just a thought if you are seriously looking at it. I got my springs today and will be working on it over the holiday. According to Chris it gives about a 1.2" drop on all 4 corners and is compatible with the stock shocks / struts so no need to replace unless shot...
Cheers!
clubairth1
29
05-10-2024 12:57 PM
SoCalJagS
09-27-2015 09:20 AM
